Apr 6, 2022 2:04 PM UTC
Zoom client doesn't start/work
Hello, after updating to Windows 11, my Zoom client won't launch or rather won't operate. According to my task manager, the client is started but I can't start/participate in a meeting nor see the app.
I have already tried reinstalling the app and deleting the browser plugin.
Is there anyone who knows this problem and may be able to help?
Thank you very much in advance.
    Apr 6, 2022 3:02 PM UTC
    Are you getting an error message?  Or it is just not allowing you to see the Zoom application?
    Oct 24, 2023 8:46 PM UTC
    No error message.  The application icon flickers momentarily, but exits so quickly it doesn't even show up in task manager.
    Oct 24, 2023 8:51 PM UTC
    Oops, replied in the wrong place, sorry.
    Oct 24, 2022 6:28 AM UTC
    I don’t know what’s happening its doing it to me too getting an error
    Oct 21, 2023 2:47 PM UTC
    I have an AMD running windows 10.  When I tried to install the app or load it, the app would briefly start to load then exit immediately.  The installer didn't seem to complete normally, probably because it couldn't launch the app.  After trying everything I could find, I installed the 32 bit version, and it's working perfectly now.  My guess is that there is a compatability issue with AMD processors, and this would only affect Windows 10 users (since Windows 11 does not support AMD).
    Oct 24, 2023 8:19 PM UTC
    Is your computer OS 64 or 32 bit?
    Oct 24, 2023 8:17 PM UTC
    jayabel, Is you computer OS 64 or 32 bit?
    Oct 24, 2023 8:49 PM UTC
    Windows 10, 64-bit.  But when the world was updating to Windows 11, my computer had to stay behind because my processor (AMD Athlon) isn't supported in Windows 11.  So that's why I think its a processor compatibility issue.  But it's super weird that there are no error messages, event logs -- nothing.  The program would just quit and that's that.  Now, with the 32-bit version, everything seems to be fine.  I suppose it could also be some tomfoolery in the registry that got fixed by overwriting the 64-bit installation, maybe it would work now if I switched back to the 64-bit version, but after what I've just been through I'll leave that exercise to someone more brave.
    Oct 25, 2023 4:28 PM UTC
    Thanks.  I have the same hardware and OS as you.  Also the exact same behavior.  No errors or anything to give me a clue to the problem.  I had not thought of trying the 32 bit version, but am very grateful for your solution, as I have now installed it and the 32 bit seems to be working fine and I have Zoom back.  Thanks a ton!
    Jul 31, 2024 4:31 AM UTC
    This works for me:
    1. Uninstall the latest 64-bit ZOOM Workplace 6.1.6;
    2. Run Cleanzoom;
    3. Download and install 32-bit ZOOM Workplace 6.1.6. ZOOM launches again.
    Hopefully, ZOOM Support will soon find the 64-bit version bug and then let us know.
