Jan 12, 2024 4:02 PM UTC
Zoom can't output sound to bluetooth headphones (android)
Hello. After the update on December 27, 2023, the sound will be output not to bluetooth headphones, but directly to the phone speaker. how to use it? Everything worked correctly before the update. My phone is samsung galaxy s20 plus. My bluetooth headphones are KZ T10
SweetEAnswer
Jan 16, 2024 12:10 PM UTC
I had the same problem and upon going through a few forums someone finally found the solution and it works. This is what you should do: add the "nearby devices" permission through the Zoom app settings.
bstrelko
Jan 12, 2024 5:46 PM UTC
Android audio is notoriously finnicky, especially when OS-established audio is used by apps like Zoom.
Can you try exiting the Zoom application entirely, rebooting your phone, establishing the BT audio connection, and then launching Zoom?
ThecicAuthor
Jan 15, 2024 6:58 PM UTC
Hello) I tried reinstalling the zoom application, rebooting the phone and launching the application after connecting bluetooth, but it did not help me( The problem appeared after updating to version 5.17.1.18472, but I cannot install the previous version. On my old phone, the zoom application version 5.16.10.17646 and everything works correctly on it
SweetEAnswer
Sep 25, 2024 3:14 PM UTC
I can't find the 'nearby devices' setting anywhere in the Android app. Where is it? I'm sure it's obvious but I just can't see it!   Thank you.
ThecicAuthor
Sep 25, 2024 5:07 PM UTC
It's in Device settings => Apps => Zoom => Permissions
CarlaA
Jan 30, 2024 6:21 PM UTC
Hi @Thecic, did any of the replies provide a helpful solution? I have seen a few posts where @SweetE solution worked. Let me know if that helped so that we can accept it as a solution. Thank you!
