Apr 28, 2025 4:14 PM UTC
Zoom camera resolution problem with Insta360 Camera
I have recently obtained an Insta360 Link 2C camera (and a Link 2 as well).
When I set the camera to 1080p and 30fps in the camera control app all is good until I open a preview or call in Zoom. Then the camera is forced back to only 720p in the camera app. While the camera is being used in Zoom the setting cannot be changed. So I pause the video in Zoom, then change the resolution, then go back to Zoom and it happens again.
This only happens in Zoom with the Insta360 Link 2 cameras. It does not happen in other video call services and does not happen with other brands of cameras in Zoom.
The zoom and camera apps are fully up to date. The camera firmware is up to date.
I uninstalled all the apps anyway and did fresh installs. No change.
PC:
Win10 Professional
Ryzen 9 3950X
32GB Ram
RTX2060
Zoom online chat doesn't understand. Insta360 have people trying to investigate the problem.
Anyone have this issue and solved it? How do I fix this please?
In every other platform the camera images are very good indeed, so I would prefer not to send them back.
Thank you.
Apr 28, 2025 10:43 PM UTC
Hi @Joe_Pineapples
try updating software/firmware
https://www.insta360.com/download/insta360-link2c
thsnks
eliot
Oct 24, 2025 9:37 PM UTC
That didn't work.  I have the latest firmware.
Sep 12, 2025 8:14 AM UTC
I have the same problem. And it seems to a Zoom issue, as it only happens with Zoom. Whenever Zoomstrats the video, the camera settings are reset to 720p.
Sep 12, 2025 1:04 PM UTC
Hi.
I discovered that my Zoom pro plan had lapsed and gone back to the basic free one which limits Zoom video to 720p anyway - that's why the camera resets to 720p to match it. If you buy a higher tier Zoom service and request higher resolution then you can have 1080p,
Sep 14, 2025 10:43 AM UTC
That's not the case for me. I still have my company Pro account. And if I plug in the other 4k webcam I have, it works just fine.
Oct 8, 2025 6:11 PM UTC
I am having this problem too!  I would love some attention or a solution to the problem.
Me too!  Please help.  I'm blurry!
Oct 27, 2025 12:13 AM UTC
Zoom HD is 720P unless you have gotten special permissions from Zoom and for most is only available on enterprise accounts for the webcam. While on a call check settings > statistics > video and most likely the resolution being used for the webcam is 360P (or lower). You can get 720P from the camera via using the second camera in screen share which uses screen sharing of the camera and the audio selected in Zoom settings > audio. In most meetings that is probably not allowed for a participant. So your experience is as expected.
Oct 28, 2025 1:22 PM UTC
No, we are entitled to 1080p with our subscription.
May 18, 2026 7:11 PM UTC
This looks like an Insta360 Link 2 / 2C firmware-level issue rather than a Zoom bug per se. I see the same behaviour with Slack huddles. The camera persists whatever resolution the last UVC negotiation set, so when a web app opens it at 360p or 480p, the Controller app and every other application sees the downgrade until you manually reset it.
Looking at the actual `getUserMedia` calls Zoom's web client makes, the meeting path requests 640×360 with an `advanced` constraints array that pins width/height to exactly that range. I'm on the free plan, so the exact number likely differs on other tiers, but the mechanism is the same: Zoom asks for a fixed resolution and the Insta360's firmware obediently switches and stays there. Most webcams treat each session's resolution as local. The Link series (and possibly other Insta360 cameras) seem to treat it as a new persistent default, which is what makes this manifest as a system-wide problem rather than a Zoom-only one.
A workaround that's been working for me: use Zoom in the browser with a userscript that patches `getUserMedia` and `MediaStreamTrack.applyConstraints` to strip resolution constraints and inject `ideal: 1920×1080` instead. WebRTC handles the mismatch on the encoder side via `scaleResolutionDownBy`, so this doesn't affect what Zoom transmits. It just prevents the camera's hardware state from being clobbered. The script applies globally, so it covers Slack and other web conferencing tools too.
Gist: https://gist.github.com/brc-dd/a6e2039f54611c4ae0a6c1e3960d5da3
ExpertswhoJohn
May 19, 2026 8:30 AM UTC
Hi All,
Let's try to pull all these things together for this post.
1. Make sure you have the Insta 360 software installed and running.
https://www.insta360.com/download/insta360-link2pro
2. Ensure you have updated to the latest firmware
3. In Zoom, select the HD Option for the camera in settings
4. Your Zoom account needs support for 1080p Support too.
This is taken with an insta 360.
All the best
John
