Jan 5, 2024 2:15 PM UTC
Zoom Camera only showing half my body
All of a sudden, my Zoom camera on my IPad only shows one half of my body when doing exercise classes.
Can someone please help me correct this problem?
Thanks!
Jan 5, 2024 3:19 PM UTC
This doesn't sound like a Zoom issue, but more like an Apple Centre Stage issue;
Center Stage uses machine learning to adjust the front-facing Ultra Wide camera when you use video apps such as FaceTime on your compatible iPad model or Mac connected to Studio Display. As you move around, Center Stage helps keep you and anyone else with you in the frame.
https://support.apple.com/en-ca/111102
Regards
