Jan 15, 2025 2:13 PM UTC
Zoom bluetooth audio crippled
I have this issue where during a Zoom meeting, the audio suddenly starts to sound crippled. On a level that I can barely understand what others in the meeting are saying. This only happens when I use a bluetooth headset. At first I thought the headset was the issue. I got it replaced by a headset from a different brand, but the issue remains. I don't have crippled sound when using the headset for e.g. listening to music. It also does not happen always. I can get the sound back to normal by disconnecting the bluetooth and then connect again. I hear from colleagues that they experience the same with different headsets and also only with Zoom.
Does anyone else recognize this problem? Is there a way to prevent the crippling from starting? It's really annoying to have to disconnect the headset in the middle of a meeting!
Jan 17, 2025 3:54 AM UTC
Audio is very complex on computer systems and depends upon many factors. You have not stated what device and OS is being used which further complicates the possibilities.
As a best guess I would guess that you did not connect to the device using the bluetooth connect feature of Zoom.
bkummelAuthor
Jan 17, 2025 4:24 PM UTC
Hi @storyhub ,
Thanks for your reply. I run Zoom on a MacBook air (M2, 2023) running macOS 15.1. I've updated to the latest version of Zoom.
Can you elaborate more about the bluetooth connect feature? As far as I'm aware the bluetooth connection is the responsibility of macOS. But let me know if there's another way to connect, happy to try!
Apr 17, 2025 6:52 PM UTC
Apple devices are very complicated when it comes to audio because Apple wants to try to control everything without giving the user much choice. Apple is very picky about integrating hardware it does not sell.
First be sure you have installed the CORRECT version of Zoom "for apple silicon". If you installed the Intel version it will not work with the headset.
Uninstall Zoom then follow:
https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0062643
Make sure that the Sony headset has been CONFIGURED as I mentioned earlier. If it is configured for music that is the WRONG setting.
Be sure that the headset is connected in Zoom's audio settings.
Be sure that all OS permissions are set for using that audio device.
Be sure that the OS audio is set to the bluetooth headset.
You may also want to try the headset on other Apple devices such as iPad or iPhone to see if it works with those devices. Be sure that all other devices have bluetooth turned off or disconnected from this device.
bkummelAuthor
Jan 17, 2025 4:27 PM UTC
Thanks for you reply, @storyhub !
I'm running Zoom on a MacBook air (M2, 2023), running macOS 15.1.
Can you elaborate more on the "Bluetooth Connect" feature you mentioned? As far as I'm aware, the only way to connect a bluetooth device is through the macOS bluetooth menu.
Jan 18, 2025 7:23 AM UTC
Apple devices have very complex audio management requiring permissions and special devices that follow all of Apple's requirements. If the device connected only supports 44.1K sample rate that can lead to issues. If the device connected is a bluetooth speaker and a mic that device may not work as a speaker device for shared audio because it is a bluetooth device. Bluetooth is not a well established standard and is not a recommended technology in the pro audio world because of many incompatibility situations. If your bluetooth headset was not produced by Apple then incompatibility is an expected issue. Additionally, bluetooth has significant latency that will throw lip sync off. As an audio engineer we avoid bluetooth devices because of all these issues. On iPads and iPhones Zoom has a separate bluetooth connect function as a part of the speaker function. A bluetooth device that works on an iPad or iPhone with Zoom may not work on a PC with Zoom even when it APPEARS to be properly connected. If you want to use Apple devices and their airplay technology it is highly recommended that you ONLY use Apple bluetooth devices. Apple does not give out all the compatibility rules to other manufacturers to force users to use only Apple devices. If you want to use non Apple devices it is best to use USB or analog technology.
bkummelAuthor
Jan 18, 2025 10:51 AM UTC
Hi @storyhub ,
I'm sorry, but this answer isn't helpful at all. If Bluetooth was really as problematic as you say, then why do I see literally everyone on the street, in the train and at the office using bluetooth headsets? Also, all the issues you sum up are different issues than the one that I describe. Using only Apple devices is also not a viable option, especially since I prefer over-ear headsets. The only option Apple has for an over-ear headset is prohibitively expensive.
Back to my issue: despite all the problems you describe with Bluetooth, I can listen music with my Bluetooth headset without any issues and with good audio quality. (Both while connected to my MacBook or my iPhone.) I can also do phone calls with my iPhone and the BT headset without problems. The only time when the crippled audio problem manifests, is when I'm in a Zoom call. So, there must be something special that the Zoom software is doing that's causing this. I was hoping that there would be some setting that I could turn on or off to mitigate the problem. Or maybe Zoom could look into this and fix their software.
