Sep 1, 2023 10:30 PM UTC
Zoom audio sources not working
I'm an experienced video conference participant using Zoom for years.  I'm a professional musician and uses the following digital audio interfaces to feed the Zoom microphone input source:
PreSonus 1824c
Tascam Model 12
Behringer UCA-222
Additionally, I use Voicmeeter Banana as a podcaster software source so that I can mix and loopback signals that originate from other programs like Ableton Live, Presonus Studio One, PG Music Band in a Box, and many others.
For some reason, I can no longer use any of the hardware devices or software sources as microphone (input) sources with Zoom.  The speaker works properly and I can see and hear these microphone sources with other programs.  But, when I select them as sources in Zoom no sound comes across the microphone test meter.  I have tried uninstalling and reinstalling all of the software and drivers that these devices and programs use, but Zoom refuses to capture sound input from them.  They do show up as eligible as input sources in Zoom audio configuration, but no sound ever registers on the Mic meter in Zoom audio settings.  Any help would be appreciated.
EliotAnswer
Sep 7, 2023 11:48 AM UTC
hi frombrandon,
current windows client is 5.15,12.
have you tried CleanZoom?
Run CleanZoom to remove Zoom completely
To remove Zoom completely, including any configuration files, run CleanZoom on your device.
  1. Download and run CleanZoom (updated July 25, 2023).
    Note: Use of the clean uninstaller will completely remove the Zoom desktop client, as well as the Zoom plugin for Outlook. The Outlook add-in, Chrome/Firefox extensions, and Google Workspace add-on are unaffected.
  2. Once completed, download Zoom from our download center and reinstall.
newl
Education Ambassador
Sep 2, 2023 12:33 AM UTC
Hello @blyons3,
Audio can get sideways fast.. especially if the virtual audio drivers are stepping on each other in a given system.  I would be happy to help but need a bit more info specific to your setup.
What operating system are you running and have you performed any updates lately.
What version of the Zoom client do you have installed?
@newl
blyons3Author
Sep 2, 2023 6:04 PM UTC
Thanks for the offer of assistance.  I'm currently running Zoom Version: 5.15.3 (18551) on two different Windows 10 machines.  I neglected to mention that using the default PC Mic works fine.  I also get normal results if I USB a USB headset from Logitech or Plantronics, but, if I try to use any of the more capable sources listed in my original post, I get no signal coming into Zoom.
Thanks!
blyons3Author
Sep 2, 2023 6:05 PM UTC
Oh,
And like most good Windows users, I try to keep my machine updated.
Sep 5, 2023 9:19 AM UTC
I'm dealing with the same issue. I cannot figure it out at all.
Sep 7, 2023 3:27 AM UTC
Let the rest of us know if you find a solution that works. I have submitted a ticket, but because the tech reps do not understand that this is not a studio setting or two zoom users attempting to account for lag time, they have not created a solution to address the issues that we have presented. They have added a background noise suppression default that eliminates live music. And the beta fix that they added to address live music only works on certain devices.
Sep 7, 2023 11:00 AM UTC
So I think there is some internal timer, some process in the background that shuts off the external mic. I have twice now reinstalled Zoom and when I first open it up, it works. And it doesn't matter if I unplug or restart Zoom or anything, it works as it should. But somewhere between 2–3 hours after reinstalling, something switches off and then it doesn't work anymore.
EliotAnswer
hi frombrandon,
Sep 7, 2023 6:22 PM UTC
I'm on a Mac, so can't use that. However, I've used a program that completely wipes out every Zoom instance.
Sep 12, 2023 12:42 PM UTC
Zoom apparently auto-updated to 5.15.12 (Mac). I was on .11 when I first posted and responded to this post. For two days now, my microphone has worked without a problem. I really hope the update fixed it, but I haven't gone crazy and tried unplugging and plugging back in to see if that could initiate it, as it seemed to do in the past. But the timer of turning off after 2–3 hours seems to be solved. It's staying connected all day. I'll update if things change.
Sep 12, 2023 11:47 PM UTC
  • It doesn't work for many of us... I have been attempting to get tech assistance on this issue for a few weeks now. Unfortunately, they have yet to provide a suitable work around. The ones offered by the tech in this chat didn't help me either. Please update if you come up with something. I really don't want to have to switch platforms that is so much trouble...
Nov 29, 2023 3:24 PM UTC
I sure wish Zoom would at least acknowledge the problem and insure us that someone is working to resolve it. I've followed Elliot's suggestion, and completely resinstalled Zoom. Unfortunately, this didn't resolve the issue of the "choppy" sounding music I'm trying to broadcast to my Zoom meeting associates. It appears that many others are having the same problem, so I have to assume the problem is with the Zoom app.
I used to be able to accomplish this with no problem, so I'm guessing one of the updates introduced the problem.
Any feedback from the Zoom support community on when we might get this issue resolved?
Nov 30, 2023 11:17 PM UTC
hi blyons3,
maybe the issue is zoom noise suppression.  you might try original sound.
Configuring audio for music and singing - Zoom Support
May 9, 2024 9:27 PM UTC
Noise suppression is not the the fix. Having the issues on win 10, win 11, with multiple audio interfaces, e.g. focusrite scarlet. The other application e.g. audacity, or ggleMeet work fine.
Jul 11, 2024 6:06 AM UTC
Any updates on this issue? Hoping to get Cubase streaming through a loopback/ black hole kind of set up through zoom but zoom may. show the driver but not submit audio detecting any signals when testing.. i have everything on my mac accessibility checked off right, dont know what the problem is.. I am nervous to invest in more equipment because this seems to be an issue that lies with Zoom and a DAW workstation it seems, i am unsure
Jul 11, 2024 6:05 AM UTC
I am having the same issues with my x 32 and cubase not sending my DAW through Zoom, nothing shows up on the meeters, have spent sooo much time on this for days of endless unrest.. I know you know this too well probably. Is there any way to get a. DAW into Zoom these days? My mixer sends only two out of 32 inputs in and acts very strange, nothing adds up with this
Jan 2, 2025 7:54 AM UTC
I've been hooped by Zoom on 2 events and unfortunately will have to find another solution. It is ashamed that a company that has made so much profit during the pandemic can leave professionals hanging like this. I thought it was the Silicon Macs, then I thought it was my interface. I even replaced my Zoom F4 Mixer with an RME Babyface Pro FS, the best of the best and it still doesn't work on any Mac Intel or Silicon M1/M3. Enough time and effort wasted, so long Zoom Meetings.
