Oct 26, 2021 11:38 PM UTC
Zoom Audio not working
I join a meeting and can see all the participants clearly, but can't hear the audio. I always check that my computer speaker is on, and run the audio and microphone test through zoom which will play the 'ringtone' and my microphone playback clearly. What can I do about this? I've also been using the same device for almost 2 years without issue until recently, and my speaker works fine with all other programs on the computer.
    Oct 27, 2021 12:15 AM UTC
    I have the same problem, but no one has responded. 😢
    Dec 21, 2025 3:21 AM UTC
    What kind of problem are you having let me know I will help walk you through it it depends on if you have the computer and iPad or smartphone or iOS it makes a difference hit me up and let's see if I can walk you through it
    Nov 14, 2021 5:50 PM UTC
    I just updated to the latest version of Zoom (5.8.3 (1581) and now my audio is not working. Also, if I try to access the audio properties dialog, Zoom hangs and I have to use Task Manager to kill it.
    Dec 21, 2025 3:23 AM UTC
    I would first suggest to figure out what device you are using it makes a difference then you need to go into settings and go to your permissions make sure your microphone and sound is working through your permissions in settings if you need any help let me know I'll walk you through it cheers Sandra
    Jan 28, 2022 6:40 PM UTC
    I am on a new MacBook Air; loaded Zoom several weeks ago.  When I start the meeting, I get audio both out and in; however, I cannot hear others when I have joined a meeting that someone else has started. Volume level on computer is high.
    Cannot figure out why this happens.
    Even Mac has its own operating system it stands alone you will still need to go into settings try the permissions to see just see if you need help let me know I'll walk you through it
    Aug 10, 2022 1:12 AM UTC
    When I host a meeting I have audio but when I join a meeting they can not hear me.
    Dec 21, 2025 3:25 AM UTC
    You might need to go into settings and check your permissions make sure your sounds microphone is enabled go through all of your permissions if you need more help let me know I'll try to walk you through it Sandra
    Aug 23, 2022 3:40 PM UTC
    same here
    Oct 6, 2022 9:24 PM UTC
    Before I could be heard if it was just the 2 of us on the meeting  but when someone else joins,  my audio stopped working.  Now I can’t be heard at all but I can hear them. My audio tests say it’s working and my mic shows the green line bobbing up and down as if it is picking up my voice but notta 🙄😏
    Oct 24, 2022 3:34 PM UTC
    Did you get this fixed yet?
    Dec 18, 2022 10:05 PM UTC
    I am having the same problem where I can see all participants but am not able to hear them when I join a Zoom call.  Speakers play okay when using other apps on my desktop.  Using a Logitech C270 since 2020 and everything was fine up until about a month ago.  My Zoom version was at 5.12.4 when the problem first started.  Tried all of the troubleshooting tips.  Then, after about a week, the webcam started working properly again up until this past Friday, December 16.  Saturday morning, December 17, updated Zoom to the 5.12.9 version and incoming audio stopped working again for the Zoom call I joined after that.  I used both my desktop (for video) and my mobile device (for audio, but this is troublesome.  Have been troubleshooting tips all day today and had to use my mobile device to connect for another call today.  I had bought a new webcam (NexiGo N660) last month but did not try it out until today as the incoming audio had started working again with the Logitech.  However, when I tried the NexiGo webcam today as a possible solution, there is still no incoming audio.  Please help.  It is expensive replacing peripherals and not finding any possible solutions.
    Dec 23, 2022 5:30 PM UTC
    I have been testing functionality every day since I started having this problem again.  The only theory that I can surmise is that the hardware compatibility with Zoom updates takes a few days to synchronize as this is what happened the first time when the incoming audio issue was resolved.  Happy that it is working again though.  Thought I was going to have to test further solutions with hardware replacements.  It would be very much appreciated to see any other posting to explain the issue and if there may be other workarounds while the issue is still being investigated.
    Dec 21, 2025 3:20 AM UTC
    Zoom is a very good app it is very simple to use download it according to whatever you are using your phone and your computer your iPad or you can use it from the browser if you need help hit me up and I will walk you through it cheers
    Dec 21, 2025 3:26 AM UTC
    It is pretty simple if you are running well it really doesn't matter what you're running it on going to your settings go down to permissions enable your permissions each one of them depending on what device you are using the settings might be different but you will still find them and you will need to enable them cheers if you need more help let me know
