Zoom Audio doesn't work with wired earbuds | Community
I'm using a 2020 MacBook Air with Zoom. I have wired earbuds from Apple, and also 3rd party ones, that work fine with the computer when I'm on any other website with sound (Netflix, YouTube, Hulu, etc.) The audio works fine on Zoom when I join a meeting and join by computer audio, but when I plug in the earbuds to the computer port, there is no sound. I've tried 3 different pair of earbuds and I've googled this question for answers. I see other people have the same question but I have not found a resolution. One answer was to change the settings or preferences on Zoom but I don't see where to do that.
Thanks.
    Bri
    Hi @jendanphil ! I have attached a screenshot of where you can update your Audio preferences in Settings. Also, have you seen this article from our knowledge base? https://support.zoom.us/hc/en-us/articles/7302459648397-Troubleshooting-audio-issues
    Hi Bri, none of this is helping me because when I sign in, and go to Settings, I get a different page than what you show. I don't have a paid Zoom account - is that why I can't get the headphones to work? This is what I see under settings: I dropped the file in below. I also tried the link above but that doesn't lead me to anything that I can do to fix this. Thanks for responding and please reply again so I can hopefully get this resolved.
    Hi. When a zoom meeting is open you can click the arrow key next to the microphone to get the settings. Here, you should be able to select the  headphones and mic (headphones on your case) that you want. Hope it helps.
    1. Make Sure The Headphones Aren’t Muted This might sound obvious, but sometimes your headphones have a mute button for the microphone.
    2. Double-Check Your Bluetooth Connection
    3. Check Your Audio Input On Zoom
    4. If Your Headphones Are Wired, Check The USB Connection
    5. Check Your Speaker Output
    6. Make Sure There Aren’t Conflicting Programs Open
    7. Check Your Permissions
    Regards,
    J Wick
    I realize this is 2 years later - but I have the same problem.  Wired earbuds work with my Windows laptop with other apps, just not with Zoom.  They are not muted, they are clearly working if I can use them in Teams or to listen to videos in various apps.  Zoom?  They aren't even listed as an option to choose in audio settings.
    I have the same issue.
    Hello there. If your audio device does not appear within Zoom, it’s possible that Zoom has not been given permissions to access it. Ensure that you have enabled access to your microphone for Zoom. Please let us know if you need further assistance.
