Zoom Audio Device plz! | Community
  • February 21, 2022
  • 47 views
Hiyo everyone,
I'm using a Macbook Pro 2017 running Monterey 12.1.
I downloaded the web client from this link https://zoom.us/client/latest/Zoom.pkg and expected a new audio device to show up in my audio settings on my mac as "Zoom Audio" but do not see it
I need this because I'm trying to get tutoring lessons on Ableton and my tutor is saying that on ableton I should see "Zoom Audio". From my experience Ableton will show any available output that the mac recognizes, so that tells me zoom isn't using it's own driver when it's on.
I think that this might be because I downloaded a web client or something? Does Zoom no longer install it's own audio driver with this version? Is this a bug?
I've scoured settings and don't see any way to enable a zoom audio device for the computer using the zoom software. Is there a different download I should use?
    Hey @seaczar, do you mind informing me more on the Ableton software? Is this something that is similar to what you're trying to accomplish?
    Reddit https://www.reddit.com/r/abletonlive/comments/fiv2kc/routing_audio_from_ableton_live_10_to_zoom_audio/
