New Member
Jun 18, 2026 6:30 PM UTC
Zoom Audio a Problem
ASUS VivoBook – Zoom Desktop Audio Fails, Browser Zoom Works
I am hoping someone has seen this before.
Laptop: ASUS VivoBook
Audio: Realtek Audio
Zoom Version: Latest version (fully updated and reinstalled)
Symptoms:
  • Windows audio works normally.
  • Music and other applications play through the speakers normally.
  • Browser-based Zoom works correctly and meeting audio can be heard.
  • Zoom Workplace Desktop does not work correctly.
  • Zoom speaker test shows activity and appears to be generating sound, but no usable audio is heard.
  • In a live Zoom meeting, I may hear occasional noises or fragments of audio, but speech is not intelligible.
  • The correct speaker device (Realtek Audio) is selected.
  • Zoom appears in Windows Volume Mixer and is not muted.
Troubleshooting already performed:
  • Updated Zoom to the latest version.
  • Completely uninstalled and reinstalled Zoom.
  • Signed out and back in.
  • Verified Windows speaker output.
  • Verified Realtek speakers as default device.
  • Tested browser Zoom successfully.
  • Disabled exclusive mode in Windows audio settings.
  • Disabled Spatial Sound.
  • Verified microphone permissions.
Because browser Zoom works while Zoom Desktop does not, I suspect either a Zoom Desktop audio-engine issue, a Realtek driver conflict, or an ASUS-specific audio utility conflict.
Has anyone experienced this on an ASUS VivoBook or with Realtek audio?
Any suggestions would be greatly appreciated.
    Jun 19, 2026 6:19 AM UTC
    Try checking if Zoom is using any audio enhancements or noise suppression features. Since audio works normally in Windows and the browser version of Zoom is fine, the issue seems isolated to the desktop app. I’d also test with a USB headset and temporarily disable any ASUS or Realtek audio utilities. Hopefully that helps narrow down the cause. Good luck!
