Jan 10, 2025 6:02 PM UTC
Zoom Application crashed when trying audio configuration with Gigcaster 8 mixer
When i'm trying to launch zoom meeting using Boss Gigcaster 8 mixer , and trying  to open audio configuration the zoom application crashed. When I"m using Zoom version 6.2.6 , It works ok. All the new versions crashed.
ExpertswhoJohn
Jan 16, 2025 10:47 PM UTC
Hi @DnyGur
I have seen reports of Zoom crashes if you set very high rates for audio.
Bring audio down to, say, 9600; higher audio bitrates could be the issue.
all the best
John
DnyGurAuthor
Jan 17, 2025 7:38 PM UTC
Hi John
The problem is not the audio high rets. It works OK on Zoom version 6.2.6.
I didn't change anything in the configuration.
It all started when I upgraded to new version.
When I return to version 6.2.6 it work perfect.
DnyGurAuthor
Mar 18, 2025 3:10 PM UTC
The problem solved in the new version 6.4.0
thank you
DnyGurAuthor
Mar 18, 2025 3:13 PM UTC
