Zoom app will not switch audio to Bluetooth | Community
  • December 31, 2021
  • 36 replies
  • 928 views
Hello
I have a tablet connected to my bluetooth speaker. I can hear any audio from any other app or sound through the browser through the bluetooth speaker with the exception of zoom.   In zoom it is specifically on bluetooth audio output but it always plays on the tablets lousy speaker.  I have gone thru all settings to ensure that zoom is playing through the BT speaker. This suggests that zoom is the problem since all others have no issues with the BT speaker.  Is there any solution to this?
Have already trying wiping the app including any data and cache and reinstalling to no avail.
    I now have an S24 and the issue persists. I have tried all of the suggestions (that are possible with android) and the Bose Soundlink Micro beeps and says "call ended" when I try to connect it to the meeting. Dang it anyways.
    I talked to Bose - they said there is no support for zoom meetings. So - it's a compatibility issue I guess? For android only perhaps?
    S24 here as well. None of the suggestions here worked for me. Tapping the speaker icon changes it to the muted-speaker icon and the audio output seems to switch from speakerphone to device, but getting it to use the bluetooth headset completely fails. Using Zoom on android device is practically useless because I can't use my mobile device in public spaces for  meetings due to this limitation.
