Oct 8, 2025 8:29 PM UTC
Zoom android problem
Hi, I’m having an issue with the Zoom mobile app. In every meeting I join, the only control that appears is Unmute. I don’t see Start Video, Share Screen, Participants, or More, even when I tap the screen.
What I’ve tried:
My camera works in the Zoom preview before joining a meeting
Rejoined meetings
Updated to the latest version
Uninstalled and reinstalled the app
Joined the official Zoom Test Meeting (https://zoom.us/test
) — still the same problem
Confirmed that hosts have not disabled video
Extra detail: If I switch my phone into split-screen or zoomed display layout, the controls appear. But when I return to single-screen mode, they disappear again. This looks like a UI scaling bug.
Phone: [insert your phone model + OS version here]
Is anyone else experiencing this? Is there a fix, or will it require a Zoom update?
Thanks!
CarlaA
CarlaAAnswer
Oct 23, 2025 7:04 PM UTC
We can confirm Zoom Android v6.6.5 will resolve this issue.  This version is in the process of being released to the Play Store.  Please update when it is available.
Oct 9, 2025 7:24 AM UTC
It sounds like a display scaling or layout bug in the Zoom mobile app. Since the controls appear only in split-screen mode, try adjusting your phone’s display settings (e.g., screen zoom, font size, or resolution) to default. If that doesn’t help, report the issue directly through Zoom’s in-app “Submit a Problem” option — it likely needs a fix in a future update.
CarlaA
Oct 15, 2025 3:39 PM UTC
Hi @Ollieb123 @MuhammadJunaid ,
I'm sorry for the inconvenience this is causing. Our technical team has acknowledged this issue and is actively working on a solution.
We do not have an estimated time when it will be fixed, but we will update you on this thread once we have the information.
For now, thank you for your patience and understanding.
CarlaA
CarlaAAnswer
