Apr 20, 2025 6:24 PM UTC
Zoom always connects to US data center (DCA) instead of EU - Need help
I'm located in Istanbul, Turkey. However, my Zoom client consistently connects to the United States (DCA) data center, which causes noticeable lag, audio/video sync issues, and slow screen sharing performance.
Even when I connect through a European VPN (Netherlands/Germany), Zoom still routes me through DCA. I believe my account or app may be stuck on this default routing.
I would like to connect to a closer data center – ideally in the EU region (FRA, DE, AMS, etc.) to improve real-time communication quality.
I am using:
- Windows 11
- Zoom client version 6.4.0 (62047)
- Free (Basic) account
Could you please help me switch my account’s default routing or advise how I can correct this?
Thank you.
**Türkçesi (bilgi amaçlı):**
Merhaba,
İstanbul'da yaşıyorum. Fakat Zoom istemcim her zaman ABD'deki DCA veri merkezine bağlanıyor. Bu durum toplantılarda ciddi gecikme, ses-görüntü senkron kaybı ve ekran paylaşımında yavaşlık yaratıyor.
VPN ile Avrupa'ya bağlandığımda bile DCA'ya yönlendirme devam ediyor. Hesabım veya uygulamam bu veri merkezine sabitlenmiş olabilir.
Zoom’un beni Avrupa’daki bir veri merkezine (örneğin FRA, DE, AMS gibi) yönlendirmesini istiyorum.
Yardımcı olabilirseniz çok memnun olurum.
Teşekkürler.
Apr 26, 2025 6:13 AM UTC
I have no issues when doing a VPN from US to Istanbul then starting Zoom. Be sure you have other data centers selected in the web portal under settings > general > data and storage.
Data & Storage
Real-time data center location
Select the data center where Zoom will process real-time data for video, audio, shared content, whiteboards, docs, and notes when hosting meetings and webinars. Selecting all data centers can provide the best experience for participants joining from all regions. Opting out of data centers may limit participants joining from those regions from using CRC, dial-in, call me, and invite by phone.
Modified
Australia Brazil Canada Germany Hong Kong SAR India Japan Mexico Netherlands Singapore Taiwan United States
x3rnAuthor
Apr 26, 2025 6:16 PM UTC
Thank you very much for your helpful advice.
I have checked the web portal as you suggested (Settings > General > Data and Storage), but unfortunately, I could not find the "Real-time data center location" option.
I am using a Basic (free) Zoom account, and it seems that this option is not available for free accounts.
Because of this, I am unable to manually select European data centers.
Even when connecting through a European VPN, my Zoom sessions are still routed to the US (DCA) data center.
Is there any way Zoom support can manually switch my account’s preferred data center region to Europe (EU)?
Or is there any alternative solution you recommend for Basic account users facing this routing problem?
Thank you again for your time and support.
x3rnAuthor
Apr 27, 2025 12:18 PM UTC
