Sep 11, 2022 9:10 AM UTC
Zoom 64 bit client changes to 32 bit client
I've tried to uninstall zoom, clean registry, boot PC, and use MSI to insure clean 64 bit install.  This places the install in Program Files.  Confirm that 64 bit is running via task manager.  Within a day, the 64 bit install is gone, Zoom directory in program files is gone, but Zoom now running 32 bit client with ProgramFiles(x86) Zoom directory created.  This is ....  Also, the "check for updates" disappears from the Zoom desktop.  It is there when first installed.  Running version 5.11.11.  Surely I'm not the only person in the world with this problem?
    Jul 6, 2023 4:24 PM UTC
    Did you ever get an answer for this?
    Mar 1, 2024 10:27 PM UTC
    Short answer, no.
    Sep 12, 2023 3:26 PM UTC
    I am having the same issue. Did this ever get resolved?
    Sep 18, 2023 3:50 PM UTC
    Is there any update on this issue?  I'm having the same issue.
    Sep 18, 2023 4:54 PM UTC
    This is Zoom.  You get updates, not fixes.  I'm frustrated.
    Nov 6, 2023 5:25 PM UTC
    The same problem is happening at our org, I opened a ticket with Zoom about it but didn't get any useful information.
    Dec 5, 2023 2:22 PM UTC
    I have exactly the same issue. This is a big problem for me because the 32 bit client crashes whenever I share screen and also seems to take up a huge amount of system resources for some reason. This is particularly problematic when I try to teach online and zoom crashes :(. On other hand, the 64 bit client works great. To deal with this, I have to be careful to check whether zoom randomly downgraded itself to 32 bit before I open a zoom meeting (which indeed can be checked by the "check for updates" option disappearing). If it did downgrade, I run a cleanzoom utility and reinstall for scratch. The 64 bit version will usually survive for a few days before I have to do this exercise again. Anyway, it's very frustrating. If anyone at zoom is reading this, please fix this!
    Dec 21, 2023 4:01 PM UTC
    Some users at my company have been struggling with this for a few months now.
    Our problem is that the 32 bit version of Zoom crashes during meetings. This is happening on both Windows 10 and Windows 11.
    What I have tried so far (with no success):
    > Clean reinstall: Works fine until there's an update
    > Clean reinstall w/ automatic updates disabled: Even with the updates disabled, it still eventually changes to 32 bit for some reason.
    > Installing the 32 bit version instead: This just cuts out the middleman and leaves us with a broken product from the get-go.
    The only solution appears to be reinstalling whenever it switches to 32 bit. This is a tedious recurrence, especially since end-users aren't aware of the bit version switch until they're in a meeting and the program crashes.
    I'm not familiar with Zoom support but I'm honestly surprised. The OP for this discussion dates back to over a year ago, and I can't find a single source of acknowledgement of this issue from Zoom themselves - just frustrated users.
    Mar 26, 2025 9:15 AM UTC
    Zoom is STILL downgrading to 32-bit when it auto updates (and randonly). It AMAZES ME that they haven't fixed this yet.
    Jun 5, 2025 11:39 AM UTC
    Same here too - driving me wild!
    Dec 12, 2025 12:03 PM UTC
    Same! Is there ANY work-around? I've uninstalled, reinstalled, Zoom still won't launch and all my classes are on Zoom.
    Dec 15, 2025 6:16 PM UTC
    I have been dealing with this for over two months. The app just never launches no matter what version I have installed. I have done the clean , uninstall, reinstall many times. Nothing has gotten the app itself to open 100% of the time. When it does, I cannot create or join a meeting or open the settings for the app. I made a post about this hoping maybe someone would have a solutions. No replies on that. This is crazy.
