jamalnuman
Zoom 5.8.4: How to control the volume of the “shared sound” that is enabled when sharing a screen?
I couldn’t figure out how to control the volume of the “shared sound” that is enabled when sharing a screen.
Currently, as a music is played on the background, its volume is so loud in the recorded video despite the fact that its volume in the computer is low
From which settings the “shared sound” volume can be controlled?
the screenshots are attached
the screenshot
    Bort
    BortAnswer
    To control the sound you are sharing directly into the Zoom meeting through share, you need to adjust the volume from the application playing the sound or the overall OS volume directly. For example, if I am playing music from iTunes or Youtube and sharing that audio into the meeting, I need to adjust the volume on iTunes or Youtube directly. You can also adjust the overall volume on your OS settings, but this will also affect the audio coming out of Zoom as well, so its generally best to adjust the volume on the application directly.
    Bort
    BortAnswer
    Hi Bort,
    Can you maybe help me please? When I am sharing screen on zoom meeting, my mic is out automatically and I can not turn it on. Participants do not hear me. When I stop sharing , the mic is on.
    thank you in advance
    Ela
    jamalnuman
    Thank you Bort for the help. It works fine
    Then the best way to manage this is to get the sound of the machine as 100 and then to tune the one of the application as we need (the screenshot is attached)
