Participant
Dec 28, 2023 2:55 PM UTC
Zoom 5.17.0 and iOS 17.1.0 loss of Original Sound
I am hoping that someone else with an Apple IPad has figured out to get ‘Orginal Sound’ back as choice the more menu.
because zoom tech support is giving me IBM (windows) solutions
BlaneARAnswer
Participant
Dec 29, 2023 10:44 AM UTC
CarlaA
Dec 28, 2023 5:35 PM UTC
Hi @BlaneAR!
It looks like there is a similar discussion and answer here: "Enable Original Sound has disappeared"
Please like the post if you found it helpful and mark this answer as an accepted solution so that others may quickly find the post as well. Thank you!
BlaneARAuthor
Participant
Dec 28, 2023 11:22 PM UTC
I did not the setting icon where he described but the screen shot that he referred posted made me think.
So after Login out of my zoom. My screen looked similar to his screen shot.
the says”Welcome. Get started with your account with the options:
Join Meeting
Sign up
Sign in
Before signing in make use of the settings icon
when given the settings that you modify choose - Meeting Settings then turn on “Use Ori
BlaneARAuthorAnswer
Participant
