Jan 10, 2022 6:51 PM UTC
When I joint a breakout room and return, my audio doesn't work - they can't hear me
Just recently, when I log on my audio works just fine, then, I go to a breakout room, audio is fine, but when I leave the breakout room, my audio doesn't work - they can't hear me. BUT, if I go back to the breakout room and immediately come out of it again, my audio works.
So, I lose audio if I transition from breakout rooms.
    CarlaA
    Jan 28, 2022 6:07 PM UTC
    Hi @simkimm
    I'm sorry for the late reply, but I wanted to check in. Are you still having this issue? If so, I want to help 🙂
    Zoom Community Team
    Sep 30, 2024 3:18 PM UTC
    CarlaA, I am having this issue with my Zoom.  I am in and out of breakout rooms frequently and, almost always, it loses my speaker connection and, infrequently, it mutes my mic.  Any thoughts on a solution?
    Apr 5, 2022 1:07 AM UTC
    I have simillar problem on my Windows Phone. When I enter a breakout room the Audio stops and when you try to switch the Mic or speaker then it briefly starts and goes off again.
