Weird: Muting mic in main room mutes system level device, muting mic in breakout room doesn't.
- August 10, 2021
- 4 replies
- 75 views
Weird: Muting mic in main room mutes system level device, muting mic in breakout room doesn't, usually ends up breaking UHD mic input and the fix is unplug/replug the uhd capture card. This is a bit inconvenient, as you might imagine.
Not sure where to post this report, is it a tech support thing or a developer thing?
(Dell m4800 laptop, latest windows updates, latest zoom update, generic magewell HD video capture USB card, updated realtek drivers, updated windows UHD device drivers)
Initial symptom began last Tuesday where I was sent to a breakout room in a zoom meeting and my UHD digital mic became disconnected and required unplug/replug to get it back, video on the same usb device was unaffected. When I was returned to the main room, audio broke, video was fine again. I have been able to reproduce and document the symptoms.
I looked at the sound panel and noticed that when I muted zoom in the main room the UHD sound panel meter stopped. Other mic inputs continued to show input.
When I muted zoom in a breakout room, the UHD sound panel meter continued to show input, which is different behavior from how zoom is muting the main room audio.
Ive attached screen captures numbered 1-5 in order. I also have a video capture of this happening.
Worked great all year until last week, the problem persisted this week after driver and software updates.
Need help with a resolution to this. Can anyone help?
