Vision Pro Audio Cuts Out | Community
I have been trying to use the Zoom App for the Apple Vision Pro.  However the audio consistently cuts out every 5 mins or so, where I can not be heard nor can others hear me.  The only resolution is to leave the meeting and come back.  There is also a Reddit thread on this as well so it is not just me.  Thanks.
    villoxAnswer
    I opened a ticket with our enterprise support folks today and got the following:
    "Zoom has acknowledged the bug and the fix is planned for Zoom client version 5.17.10. The tentative date for this release GA is February 25th."
    I'm having the same issue. Makes Zoom unusable.
    Same issue. I noticed that it happens pretty consistently when a notification comes through.
    Have you tried turning off notifications while in a call to see if it helps?
    I tried that this morning, it did seem to last a little longer, but still cut out 4 times in a 30 minute meeting.
    Same issue here. I couldn't hear anyone on the call. It's a shame as the Discord compatible app on Apple Vision Pro works fine.
    Seeing the same. I will try leaving notification off for now. Good find. Seems like this is a bug that should be solvable.
    Just had a call and I had no notifications on. Audio still dropped after 5-10 minutes so maybe it also happens for other reasons.
    villoxAnswer
    Thanks for the update!
    Same issue
    same thing for me. It's really annoying.
    I also have the same issue. Looking forward to the update!
    Still having this issue, and showing no update available for visionOS.
    Any chance we could get an update on when this is expected to hit?
    Can someone pse give the accurate release date for this fix? Thx
    Agreed.
    To be clear, this bug makes the visionOS Zoom app almost entirely unusable for me. At best, I can keep Slack running on my laptop and switch into the visionOS app when I need to show someone my view - but only if it's of very short duration.
    Otherwise, I'm completely unable to use the visionOS app for anything productive.
