Mar 7, 2022 9:08 AM UTC
Virtual background doesn't work.
Does anyone know why I can't use a virtual or blurred background on a basic plan? I used to be able to but the options disappeared. I have an apple mac with all the requirements needed to set up a virtual background.
    Mar 7, 2022 5:25 PM UTC
    @JessicaVlasova did you upgrade or change anything on the Mac lately?  If it was there, nothing has changed on the Zoom side regarding Blur and VB, so I am wondering if another change is conflicting with Zoom now.
