Video is using a low resolution substream
I  am running out of ideas  and need help.
My zoom video is hugely pixelated.
Using windows 10 with a network camera  supported by microsoft ONVIF driver. The camera appears in device manager as a detected camera and can be used by Zoom.
When I check the video with the Microsoft "Camera" app - everything looks perfect.
When I start zoom, it picks a substream which has a terrible quality. I don't know why and unfortunately I cant change it.
I also have the camera displaying video on a network controller, and it shows there OK all the time.
Unfortunately, my camera has a problem that even if I disable the substreams in the settings, and save the configuration, it reverts back to enabling the substreams.
My questions are:
1.  Why does zoom picks a substream why all other apps pick the main stream ?
2. How can I make zoom pick the main stream ?
