Sep 30, 2024 9:43 PM UTC
Very choppy audio when listening to audio screenshare
 I attend meetings often and sometimes I need to listen to audio screenshared from other people. The sound from the screenshared videos is very choppy and sometimes extremely muffled (the visual portion runs smoothly). About one in every four times there's no audio at all. I've checked to see if my drivers are all up to date - they are. It's a 1 1/2-year-old computer running Rectify11 with plenty of RAM. I've never had this problem before on any other computer. Any suggestions?
Thanks in advance,
Zack
P.S. I've had this problem for a while now.
Oct 3, 2024 7:36 AM UTC
Choppy streaming can be that the participant sharing did not optimize for video, has limited upstream bandwidth (usually caused by using WiFi instead of ethernet), or the receiving participant has internet bandwidth issues or computer processing power issues. You would need to run tests to decipher the cause.
