Using zoom with with veed teleprompter | Community
  • February 6, 2022
  • 127 views
When making  a virtual presentation on Zoom to your audience the veed teleprompter allows you to look directly into  the camera while the script is rolling to effectively make the presentation.  Problem is because the mic and camera must be used by the teleprompter software, when you go to the zoom meeting the screen is black. Other platforms allows this effective tool to be used simultaneously.   The presenter may not be able to see the audience while using the teleprompter; but the audence can see the  presenter. After the presentation the, presenter clicks out of the teleprompter screen allowing to return to the zoom  meeting to answer questions  and  additional dialogue.  Zoom needs to move up its features to assist with this most effective feature for presenters.  https://www.veed.io/teleprompter  gives a glimpse at this process.  Caution: It does not work the way it is explained in the video.  Just adding  the video to give you some  prespective.
    Hey @DII I have not used the veed.io teleprompter myself, however, here's a good external resource on How to use Veed.io within Zoom on YouTube. As it's been some time since you've posted this try updating your Zoom client as well.
