Using "Virtual Cable" software with ZOOM
good evening
I use the VMIX software together with the VBCABLE_Driver software
For a live broadcast to your ZOOM software
Recently when I show a movie in VMIX software together with VBCABLE
The video looks great
But the sound doesn't sound clear at all
Do you have a way to help me?
That my participants will also hear the sound perfectly
    Inside of Zoom, you can select CABLE Input for your microphone and CABLE Output for your speaker. This will allow you to send your microphone audio into Zoom using the virtual CABLE Input and receive audio into Zoom using the CABLE Output. In order to send audio out of OBS you will need a plugin called Audio Monitor.
    Regards,
    John
