Using Meeting SDK Without Publishing | Community
  • June 3, 2025
  • 0 replies
  • 52 views
I do not plan to publish my app on any app store (Google Play or App Store). I only want to use the Meeting SDK for internal or private use.
Is it possible to use the Zoom Meeting SDK without publishing the app?
Will I need to go through any approval process for SDK usage if my app is private?
Domain Verification for Multiple SDK Accounts
If I use multiple SDK accounts, but all meetings are hosted on only one domain, do I only need to verify that single domain once? Or does each SDK account require separate domain verification?
Development vs. Production Keys
I noticed that there are two types of SDK keys: Development (dev) and Production (prod).
Which key should I use for my application?
Are there any restrictions when using dev keys compared to prod keys?
Do I need to switch to prod keys before deploying my app, even if it’s for internal use only?
I would appreciate your clarification on these points.
Looking forward to your response, also I would appreciate any advice if there is a better way.
