May 2, 2024 11:02 AM UTC
Using laser pointer whilct screen sharing
Is it possible for a participant in the meeting to use a pointer whilst we are screen sharing. The host would not be using the pointer at the time
Humashankar
May 2, 2024 12:17 PM UTC
Hi @Supraman
Would you like to use the Spotlight feature - Zoom Spotlight, cursor into a red dot - More steps available in the below article - incase if it helps you current need.
Since laser pointer is not achievable.
Sharing your Screen In Zoom.pdf (bard.edu)
Hope this helps - Happy to help further!!
Thank you very much and have a great one!
Warm regards
Humashankar
Hi @Supraman
Warm regards
SupramanAuthor
May 8, 2024 10:24 AM UTC
Great and thanks for the assistance
