Oct 9, 2023 11:10 PM UTC
Using external webcams for Zoom calls on iPadOS17?
Using external webcams on iPadOS17 is now supported. It works for Facetime. But I have not been able to get an external webcam working on my iPad for Zoom calls, despite having updated my iPad to iPadOS17. Are there settings to make this work, or perhaps use of external webcams on an iPad is not yet supported by Zoom?
Oct 19, 2023 2:28 AM UTC
@rodneysing & @fernelius -
Zoom is planning to add external camera support to iPads running iPadOS17 early next year.
Oct 11, 2023 12:11 AM UTC
I’ve been watching for this too.  When will Zoom be adding support?
I take notes on my iPad while in Zoom conversations.  Having the camera on my monitor while doing so rather than on my lap as a part of the iPad would be extremely helpful.
bstrelko
Oct 19, 2023 2:56 PM UTC
@aaroncoffman will external audio devices be supported (if not already)?
Also, would ext camera/audio support be for Zoom Rooms for iPad, Zoom Client for iPad, or both?
Jan 12, 2024 5:25 PM UTC
@bstrelko - at this time, I don't have details on potential Zoom Room for iPad support of external cameras.  Unfortunately, I don't have a camera that is supported on iPad so I'm unable to test it.
Oct 19, 2023 2:00 PM UTC
Good to know. Thanks for the update!
Dec 15, 2023 2:31 AM UTC
Just wasted $200 on a webcam.
Jul 30, 2024 12:49 AM UTC
July 2024
I have an IPad 17.5.1 IOS and Zoom PRO version 6.1.5 -Is external camera support added for use in  Zoom meetings now ?
May 6, 2025 4:50 PM UTC
@WS4 ,
Yes, I would expect this to work now.
Apr 3, 2025 5:38 AM UTC
any news on this?
May 6, 2025 4:42 PM UTC
Hello @ts44444  - other than enhancements for bug fixes, I don't believe we have any specific updates.  Is there something in particular you're seeking?
Sep 4, 2025 4:55 AM UTC
I just purchased an HP series 7 pro display with built-in webcam, but it doesn’t work for Zoom on my M2 iPad pro (iOS 18.6.2). Connection between the iPad and the monitor is via Thunderbolt 4. I’m not sure if others are having issues with monitors with built-in webcams, but could this please be addressed soon?
Sep 4, 2025 6:51 PM UTC
@applemacker - sorry to hear about the issues you're having.  Do other apps that leverage cameras work?  For example, are you able to make a FaceTime call using that camera?
If you've validated that the camera works on another application, but you're unable to get it to work on Zoom, you may want to open a ticket. https://support.zoom.com/
Sep 6, 2025 6:49 AM UTC
I was able to get it to work. User error on my end. Thank you @aaroncoffman for the simple but effective question!
New Member
Jul 18, 2026 5:16 AM UTC
Hello! Just got an OBSBOT Tiny 3 with the hopes that i could pair it with my iPad Mini 7 to take on the go. However, I think Zoom App on iPad still does not allow to change video sources to anything other than the iPad’s native cameras. Any news regarding when this feature will be added?
