using external camera and its lapel mic with cam link? | Community
  • March 5, 2023
  • 38 views
Hi I have an external camera which Im  connecting to zoom via cam link .
I also have an external microphone but there is a delay . I can clean up this delay but it requires purchasing expensive software (audio hack and loopback which is $156)
I also have a DJI lapel mic which i can plug into the camera, but when i do that , the video is from the cam link  but the audio is from the internal computer mic. Its as if the lapel mic is not welcome.
Is there a way to tell zoom to use the audio from the lapel mic and not internal computer microphone when connected via cam link?
I have also tried connecting my external camera via USB and the problem is the same.
Or is there a way to fix the delay for the external mic without purchasing expensive software?
Many thanks
    I have a similar problem.  I have this lapel mic that I bought on amazon.  It works in other apps, but doesn't work with zoom.  https://www.amazon.ca/VIEWLON-Microphone-Reduction-Recording-Interview/dp/B09QJZ25N1/ref=sr_1_1_sspa?keywords=viewlon%2Bwireless%2Bmicrophone&sr=8-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&th=1
