Using an audio interface and Ipad
Hello!
I am using an audio interface connected to my Ipad. I use two audio sources. Using the standard camara app to shoot a video, both audio channels are recorded perfectly.
Now i want to use both audio channels in a zoom call. Sadly here only the first audio channel is audible for the participants of the meeting. Do you know any solution to that problem?
Thanks a lot. Solving this would be so very helpful for me.
    asaisias
    same
    PMilzAuthor
    It seems it works when using Zoom in a browser, so this could be a workaround.
    PMilzAuthor
    Seems like no one reacts. I will need it again tomorrow morning, then i can report if the workaround in the browser works.
    In general it seems that the browser version has more audio options than the app.
    PMilzAuthor
    Since there is no reaction by an expert and zoom does not work properly for my purpose:
    does anyone know if it works with some other video call app?
