Jul 19, 2023 3:01 PM UTC
Using 2 or more BZXZB Wireless Clip-on Microphones (Laptop)
Good morning -
I purchased a two pack Dual Wireless Lavelier Microphone (BZXAB K-37) from Amazon. There are two clip-on mics in each pack. I would like to use as many microphones as I can for my meeting tomorrow. If I can only use two, that is fine, but I am not sure whether I am able to use more than one. I do not have a Zoom Room system. We will be in a backyard. Two folks will be joining us on zoom, and the rest in a circle in the grass. It may sound casual, but it's a high stakes meeting. I want to be prepared. IF you have experience using a dual Lavelier clip-on mic system (or more than 2), I would really appreciate your advice. Thanks.
-WildSalmon
