Italiangen2022
Contributor I
Contributor I
Nov 29, 2023 8:40 PM UTC
Use specific audio input channels not in Settings
Hi,  I'm trying to solve an audio issue and noticed that the audio dropdown does not include "Use specific audio input channels"  I'm using a Pro account and the client version 5.16.10 (26186)
Basically, I'm using a Behringer Flow8 digital mixer with 3 active mics during a webinar.  Zoom keeps dropping the mic input.  Does Zoom accept ASIO drivers? I'm using Windows 11 Home 23H2 on a ThinkPad P14S 64-bit 2.2Ghz, 24GB Ram
Any and all help would be appreciated.
Peter
ExpertswhoJohn
Dec 4, 2023 10:55 PM UTC
hi @Italiangen2022
Zoom uses the audio given to it by Windows.
It will connect to a new device when seen by Windows which allows you to plug in a USB headset and have it be used automatically. And if removed, switch to another source.
I assume that Windows is reporting the loss of the driver and Zoom then responds by disconnection.
i would try something like OSB (just for audio)  and see if that keeps the ASIO drivers connected and then send the audio on to zoom.
all the best
John
