Updates and what versions work | Community
  • October 6, 2021
  • 3 replies
  • 36 views
I have a group of users who join a weekly meeting, just had them update their Zoom version to 5.8 at the direction of a Zoom colleague. Now one of my users asked this and I hop you can answer it:
"I’m on Apple i-Mac with the “Mojave” operating system on a 2013 Intel processor which is two upgrades back because later upgrades can’t run 32 bit apps and I have some I can’t do without. I downloaded from the link you sent but before opening I need to know if it will run on my older i-Mac. Let me know if it is OK to open."
    Rupert
    Hi @BrantBiblehost
    The Zoom client requires at least macOS 10.9 or later.
    Mojave is version 10.14 - so you should be fine. Just.
    https://support.zoom.us/hc/en-us/articles/201362023-System-requirements-for-Windows-macOS-and-Linux
    Hope this helps.
    Rupert
    Thanks Rupert, I appreciate it and will pass this along!
    Rupert
    You're welcome. Glad to be of assistance. Please click on Accept as Solution if your question has been solved.
