unstable network connection and low band width messages
Hello
I have recently changed internet provider, but am still getting the following 2 messages;
'Low band width' and 'unstable network connection' when I first log into a meeting as host.  I am also on mute when I haven't changed anything.
Is this a Zoom/settings issue or is still to do with my internet??
Many Thanks for your advice
    Partner
    April 27, 2024
    I have the same issue. Tried everything that was suggested but still get the messages and very unstable zoom sessions. Did you find a solution
    Same issue here.  I have even tried connecting with an ethernet cable.  I really need help!! I posted a different post with no response.
    Partner
    May 18, 2024
    I had the same issue. It is not your provider.  I Tried everything obvious too. Took my chrome book to geek squad and he told me that due to zoom “improvements” this year, low end processors will be unstable.  It requires a minimum of i3 processor and 8gb ram. I bought a new Chromebook with i5 processor and 8gb ram a
    Partner
    May 18, 2024
    I had the same issue. It is not your provider.  I Tried everything obvious too. Took my chrome book to geek squad and he told me that due to zoom “improvements” this year, low end processors will be unstable.  It requires a minimum of i3 processor and 8gb ram. I bought a new Chromebook with i5 processor and 8gb ram and this resolved the issue of an unstable network.
    May I ask what device you bought?  It’s so frustrating as my Chromebook isn’t even a year old!
    Partner
    May 18, 2024
    Minimum of i3 processor and 8gb ram is now required due to zoom “improvements”.  I bought an i5 w/8gb ram. Problem solved.
