Unable to log in b/c zoom says to "click allow on my other device" when I have no other device | Community
  • February 2, 2023
  • 3 replies
  • 28 views
When I attempt to log-in to zoom, I get "In order to verify...blah...blah, click on ALLOW on your other device"
I have no other devices.
he only way around it is generate a special code that is emailed to me.
Why isn't my userid/psw sufficient to log into zoom and why is your ALLOW message so obtuse without any other options? I missed a meeting and was in a fit of rage b/c of this.
    newl
    Education Ambassador
    February 2, 2023
    Hello @Tmanpdx,
    It sounds like the Zoom account that you are using has a 2-Factor Authentication
    process as part of the login.
    This is usually imposed by the account owner (i.e. your employer or school)
    I would check with the organization that provided you the Zoom account for more details
    as the 2-Factor Authentication could be via Zoom's 2FA or a 3rd party provider like Duo, Okta, RSA etc
    Hope this helps!
    TmanpdxAuthor
    Nope.
