Two screen / dual monitor issues | Community
  • February 9, 2022
  • 23 views
Hi there,
I use an iPad as my second screen with a teleprompter which basically works well. But on the second window that is on the iPad I can only see myself instead of the other attendees. Only if I share my screen I see all attendees on the iPad screen. The second window on the iPad does not have any screen controls so I cannot switch windows from the main screen to the iPad because I need the controls on the main screen.
Any ideas how to fix it?
Cheers
Michael
    Hey @michaeloeser just to clarify and understand your setup, are you using a Mac with an iPad as a second 'monitor' with Apple sidecar?
    I have the same issue. And, yes, I am using an ipad with the current iOS updated. It sits in the try of the teleprompter. And I have an extra-wide monitor below it. This orientation is also reflected in the display settings in the system preferences.
    What I want is Speaker on the iPad so I maintaining eye contact. And gallery view or screensharing for the lower, bigger monitor.
    How can I change these things? What I get now is screen sharing on the iPad and the speaker or gallery on the large computer.
    Is there a way to switch these?
    Thx!
    -dc
