Switch microphone by hot keys | Community
  • April 15, 2022
  • 3 replies
  • 53 views
Does anybody can help me: how to set smitching microphones during the meeting in Zoom? It will be cool if I can make it with hot key.
    April 16, 2022
    @missvladis  – this Zoom Support article has all the hot keys available in each type of device.  Unfortunately, switching between microphones isn’t supported.
    I personally use a Stream Deck to perform this function for switching between mic, headphones, speakers, etc. Set your mic and speaker to “System device” then use the Audio Devices plugin on the Stream Deck to change the assignments of default devices.
    Gauranga
    I am also looking for a way to connect 2 USB microphones in a Zoom meeting but can't find any solution. To manually switch between the microphones is just not acceptable. It takes too long.
    I also want a way to use a hotkey, some way to make a StreamDeck select the Audio devices in Zoom.  I don't want to change whole System Audio device, just the Zoom Speaker output in certain situations.
