Feb 23, 2022 7:59 PM UTC
Split screen or side by side screen
I've just joined the Zoom and still trying to figure out how I can set up the Zoom meeting for my needs.
I'll be instructing a drawing class session and would like to use an online model  posing on the part of my screen and I'd like to use live video input set up of my drawing demo that I'd like to shows side by side on my screen, so the viewer sees two split screens on their screen. Can this be possible? If so then how ?
Thank you!
    Mar 27, 2022 8:19 PM UTC
    I need to do this too.  Did you figure it out????
    Thanks,
    Margaret
    Jun 8, 2022 8:14 PM UTC
    I am only able to split screens using the dual monitor option.
    https://support.zoom.us/hc/en-us/articles/201362583-Using-Zoom-desktop-client-with-dual-monitors#h_01FZEDD9M6GWA86RDH96T1DQ55
    I have one window with the guests and controls and the other is a video, presentation or the person speaking.
    Hope this helps
    Jul 28, 2022 8:13 PM UTC
    I also need help with this process as I have the Curve Monitor.
