Feb 19, 2023 9:32 PM UTC
specific audio input selection not saved
Hi everyone. I am so grateful Zoom finally can select specific audio inputs. The only problem with this new feature is that it doesn't seem to save the inputs you select. You have to rechoose your specific inputs every time you join or create a new meeting. Does anyone know a fix for this?
    Feb 20, 2023 8:50 AM UTC
    Sign in to the Zoom web portal as an admin with the privilege to edit account settings.
    In the navigation panel, click Account Management then Account Settings.
    Click the Meeting tab.
    Under In Meeting (Advanced), verify that Allow users to select stereo audio in their client settings is enabled.
    If the setting is disabled, click the toggle to enable it. If a verification dialog box appears, click Turn On to verify the change.
    (Optional) If you want to make this setting mandatory for all users in your account, click the lock icon unlocked-button.png, and then click Lock to confirm the setting.
    Feb 24, 2023 12:46 AM UTC
    I'll try that and report back.
    Jun 28, 2023 8:03 AM UTC
    Bump. This exact issue causes me a lot of grief every day.
    @toadcarpool I had a sort of success with it by leaving the zoom settings window open, although not sure it works every time.
    Surely there it a way to save the preference?
