Speaker window goes dark when speaker is talking. | Community
Roger_Blair
  • December 29, 2023
  • 20 replies
  • 124 views
I'm running the current version of Zoom on a Windows 10 laptop. When I'm in a meeting, the speaker's window goes black while he/she is speaking and the yellow line surrounds the window. In Speaker view, the speaker's thumbnail appears, but the main window is dark. I've uninstalled and reinstalled Zoom, but the same thing happens. How can I fix this?
Best answer by rn-zm
Hi @Roger_Blair welcome to the community! Are you still having this issue as of today? You referred to the internet that you're currently connected to that maybe degrading your meeting performance. Have you tried other networks recently to see if your meeting experience has changed?
Otherwise, you could attempt to disable these video settings that maybe utilizing more hardware from your device when receiving video.
Same, started happening in late December.
Uninstall that version and goto ; https://zoom-us-zoom.en.uptodown.com/windows/versions and install an older version. The update of December is the problem
J’ai le même problème ! J’ai désinstallé et réinstallé zoom sans succès !
I am having the same issue with my MS Surface Pro 8. Is there a resolution? It is quite annoying.
Thank you,
Mike
J’ai désinstallé la dernière version pour la remplacer par une version antérieure, apparemment cela résout le problème. Allez à ; Anciennes versions de Zoom Cloud Meetings (Windows) | Uptodown
Me too, any solutions?
Uninstall that version and goto ; https://zoom-us-zoom.en.uptodown.com/windows/versions and install an older version. The update in December is the problem.
I have been experiencing the same. Most recent update is installed.  Not finding  any solutions on Zoom support page.  UGH!!!
Uninstall that version and goto ; https://zoom-us-zoom.en.uptodown.com/windows/versions and install an older version. The update of December is the problem.
Having the same issues, just started over the past week, very annoying!!
Uninstall that version and goto ; https://zoom-us-zoom.en.uptodown.com/windows/versions and install an older version. The update of December is the problem!
Thanks. I rolled back to Version: 5.16.10 (26186), and that solved the issue. Hopefully, a corrected version will be released soon. Thanks again!
Can we get an update from Zoom?  Is there a fix yet?  What are the versions that do not work?
Uninstall that version and go to ; https://zoom-us-zoom.en.uptodown.com/windows/versions and install an older version. The update of December is the problem.
Video problem ?
