Mar 9, 2026 2:18 PM UTC
Sound is not working in a recorded Zoom class
I recorded a Zoom class and saved it to my laptop.  We use Windows.  The sound is not working in the recording.  The audio was not muted during the recording.  I have realized that the sound works in recordings that are stored in Zoom cloud storage.  Is there anything I can do to fix this issue?
    tom cary
    Contributor I
    Contributor I
    Mar 9, 2026 2:32 PM UTC
    If the recording was saved locally, Zoom usually creates separate files for video and audio. You might want to check the recording folder to see if there’s an audio-only (.m4a) file and try playing it separately. Also, make sure the recording finished converting properly after the meeting. If the issue continues, re-running the Zoom recording converter might help.
    Mar 9, 2026 2:37 PM UTC
    Thank you for the information.  I found the audio saved separately.
