Oct 27, 2025 11:14 AM UTC
sound distorded when shared from itunes
Hello!
I'm sandra Benetti, user of zoom
i need to share sounds through itunes in zoom meeting.
zoom workplace 6.5.12 (14128)
itunes 12.13.9
i tried to use musician mode in zoom
i tried to use audio parameter set to direct sound in itunes (instead of windows audio session)
the sound is "cheap" and distorded
when i use another player, it works
does anyone has had the problem and solve it?
i'm running windows 11 on an acer laptop AMD Ryzen 5 5625U
thank you for reading my post
have a nice day
regards,
Sandra
Oct 30, 2025 6:06 AM UTC
As an audio and broadcast engineer I can tell you that computer audio can be very complicated. itunes audio is a simple share audio method which use the output from your sound card and does not involve using the mic audio.
