Nov 28, 2021 12:24 AM UTC
SIMPLE QUESTION. PLEASE HELP ME.
hi everyone, yday i went to MY PROFILE & SYNC GOOGLE CALENDAR> after that> every calender event in my google calendar keep on popping up in my laptop as a reminder. please help me> HOW DO I DISCONNECT THE GMAIL ACCOUNT WHICH I added to my zoom account yesterday? Thx, Jem.
    Nov 28, 2021 10:07 PM UTC
    Hello Jem,
    You may want to consider the following actions:
    Remove third-party app access
    1. Click the avatar at top right of your Gmail page,
    2. Then click "Manage your Google account".
    3. Click Security and scroll down to "Third-party apps with account access".
    4. Click "Manage third-party access", and click on the app (Zoom) you wish to remove.
    5. Click Remove Access.
    Other resources:
    Here is how you de-install Zoom for each option
    • For add-ons:
      • Go to the add-on page in the GSuite Marketplace (Link to Zoom addon) and click “Uninstall”
    • For extensions:
      • Find the app on the Chrome web store (Link to Zoom chrome extension) and click “Remove from Chrome”
      • Alternatively, see all your extensions at chrome://extensions/. Remove the extension.
    Dec 10, 2021 9:04 AM UTC
    Its not a tough task to for any user you first need to go to the manage you account and then click on the third party apps and then click on zoom app to remove access I also done the same process here in my account.
