Feb 11, 2023 1:13 PM UTC
shortcut key for simultaneous interpretation language shifts for Macbook (Urgent and urgent)
sorry i am in such a hurry.. Really really urgent
In Windows - the simultaneous interpreter's language shift shortcut key is
ctrl/shift/C
but I don't know how to use that in Mac
Please tell me the Mac version of this ..
i have to do simultaneous interpretation in like 10 minutes and have no clues for this
Please please help.....
Feb 12, 2023 2:09 PM UTC
Well I need the shortcut key for the current version.. because I am using my company zoom and I can't just downgrade it myself ㅠㅡㅠ
I am pretty sure there will be the shortcut key for language channel shifting in macbook..  I saw people using it and I definitely need one since I can't do my job with my mouse with more than 20 people talking in their own language....
Somebody who didn't test it  said that the shortcut was   Shift + Command + Space
Could you please try and please let us know if it worked ?
Feb 11, 2023 3:53 PM UTC
Shortcut keys are listed in the Settings window.
sunchulAuthor
Feb 11, 2023 3:57 PM UTC
Sadly.. simultaneous interpretation related shortcut keys are not written there... interesting they exists secretly. They are not written there ㅠ I just found out after I tried almost all the keys and searched it on Google...
sunchulAuthor
Feb 11, 2023 3:58 PM UTC
But still failed to find the one for MacBook simultaneous interpretation language channel shift shortcut key...
Feb 11, 2023 11:16 PM UTC
it is unverified but try
cmd+shift+L
If it works, please let us know.
Feb 11, 2023 11:17 PM UTC
It's cmd+shift+L
I assume you need this now because the latest update apparently has a Mac glitch that affect the interpreter's control and causes the bar to disappear or move around the screen randomly. Please let me know if this solves the problem. A lot of colleagues are reporting the same issue (I'm on PCs, so I can't test it myself)
Feb 11, 2023 11:55 PM UTC
Thank you Katty!
sunchulAuthor
Feb 12, 2023 1:45 AM UTC
It doesn't work ㅠㅡㅠ.... so sad....  umm.. do you know how to change it on the zoom settings??(I can't even see it on the settings page about simultaneous interpretation language changing) It doesn't work and I don't know why....
Feb 12, 2023 4:06 AM UTC
too bad, worked for me in Windows, sorry
Feb 12, 2023 2:02 AM UTC
As noted above, it is a known issue with the latest version of ZOOM on Mac OS devices.
Your only options at present are to find an earlier version (if you kept a 5.13.3 file, for exampls), uninstall the current version and install the old one (be sure that you don't have "automatic updates" selected for your account) or, alternatively, try an external device such as Streamdeck. @cyril Flerov has suggestions. See his LinkedIn.
Feb 12, 2023 2:46 PM UTC
hello everyone, now when we have found the shortcut for Mac, the solution should work: if you get the simplest version of Streamdeck, https://www.amazon.com/Elgato-Stream-Deck-Mini-customizable/dp/B07DYRS1WH/ref=sr_1_6?crid=12LNJ1M8YH8KR&keywords=stream+deck&qid=1676212970&sprefix=streamdeck%2Caps%2C427&sr=8-6&ufe=app_do%3Aamzn1.fos.18ed3cb5-28d5-4975-8bc7-93deae8f9840
[works both in Mac and in Windows] you will be able to configure 1 of the buttons to act as a language switcher. What I recommend to do is to create a multi-action button that will first  recall zoom to the foreground and then switch the language. Then even if you are not actively showing the zoom window [for example if you open the word document] if the language switches all you need to do is to press the button, Zoom is going to be brought to your screen automatically and the languages going to be automatically switched. No keyboard/mouse fiddling involved 🙂 if you use any other keyboard shortcuts in zoom, Streamdeck allows you to configure any of them. I did not test it  on Mac, but for Windows it works for me perfectly.
