Jan 14, 2022 12:56 PM UTC
Sharing problem
I have always used Zoom by creating a connection from the Mac and sharing my iPad with the Goodnotes app but now it seems to no longer work. I don't see the attendees and they don't see me plus when I write Goodnotes on the iPad the attendees see a black page. I use a Mac with Monterey 12.1 and an iPad with. iPadOS 15.1.
    CarlaA
    Mar 7, 2022 7:58 PM UTC
    Hi @stegra , thank you for using the Zoom Community to seek support. I see you asked your question a bit ago and have yet to receive a response… I apologize for the delay! I appreciate your patience.
    Are you still experiencing this issue?
    Moderator
    Zoom Community Team
    stegraAuthor
    Mar 8, 2022 7:28 AM UTC
    yes, I still have the problem
    CarlaA
    Mar 8, 2022 9:42 PM UTC
    Can you try this?
    system preferences—>sharing—>turn off AirPlay Receiver
    Restart all devices
    After that is done,  please try the airplay again. Keep me updated!
    stegraAuthor
    Mar 18, 2022 6:51 AM UTC
    I did what you suggested but nothing has changed. Now I have updated to Monterey 12.3 and iPad OS 15.4 but the problem remains.
    CarlaA
    Mar 18, 2022 9:11 PM UTC
    Hi @stegra I have assisted in converting your inquiry into a support ticket to further investigate.  Please watch out for a follow-up email with information on your case.
    Once you receive a resolution, please feel free to come back to this thread to update the community if you can 🙂 that way other members of the community with a similar question can easily find your thread. Thank you!
