Sharing ipad via cable results in buzzing noise every 30 seconds
I recently upgraded to a 5th generation iPad Pro. When I have my iPad Pro connected to my MacBook Pro and during a Zoom meeting if I select share ipad via cable, there is a loud buzzing noise that happens every 30 seconds that all participants can hear. If I remove the cable and choose share ipad via airplay, there is no buzzing sound.
This behavior is something new with the 5th generation iPad. If I connect my 3rd generation iPad Pro (same configuration, IOS version, and apps as the 5th generation) and choose share iPad via cable, there is no buzzing sound.
I have the lastest IOS versions on my MacBook Pro and iPad Pro and the latest version of Zoom.
Is anyone else having this problem? I have contacted Apple support several times and after trying many things, they say contact Zoom of course. I have an appointment at the Apple genius bar later today to have the look at it.
    CarlaA
    CarlaAAnswer
    Hi everyone, until a Mac software update is released to fix this issue, I would suggest one of these two options that some have shared in this thread 🙂
    • Share the iPad via airplay.
    • Join the iPad to the meeting using the Zoom iOS client and share directly from the iPad.
    Carla,
    Zoom Community Team
    I also today upgraded an old (non-M1/M2) iPad to 16.1.1 and no buzzing. But I think the issue might have been related to M1/M2 iPads only. So, no wiser really. Was anybody having this issue with non M1/M2 iPads? Thanks
    I’m using the 2021 M1 iPad updated to iPadOS 16.1.1 and the buzzing is still there.
    What operating system are you using on the M1. perhaps reinstall the Zoom application?
    It really has nothing to do with Zoom. It’s an Apple issue. The iPad makes this buzzing news not only in Zoom but in Ecamm Live and other recording software. It happened in iPadOS 15 until it was updated to 15.7. Apple needs to resolve this and it’s been reported to support. I just wanted to let people know it’s still happening.
    Updated my iMac to Ventura 13.0.1, iPadOS 16.1.1 and the issue remains. I do believe this is an M1 iPad issue not sure about the M2 iPad. I sure hope Apple gets it fixed soon. I can mute the iPad on Ecamm, does anyone know if there’s a way to mute the iPad in Zoom?? Thanks.
    I tried muting the iPad in multiple ways (input and output, in Zoom and system-wide with hardware and software)). All it did was give me an audio echo, which was bizarre, and didn't solve the problem. The buzz was not coming from the iPad microphone or speakers, but from the speakers I have connected to my laptop.
    Mine is absolutely the iPad! In any other programs I can detach the audio from the iPad recording and delete it.
    Here's the thread on the Apple iPad forum:  https://discussions.apple.com/thread/254327379?answerId=258171700022#258171700022
    Note that one person said it is based on the USB-C port change from Lightning, and not the M1/M2 chipsets.
    CarlaA
    CarlaAAnswer
    Carla,
    Zoom Community Team
    This is not a solution for those of us that cannot use airplay or need to switch between sharing the Mac desktop and iPad screen. This problem makes zoom unusable for one of my main use cases. What is the timeline for fixing this problem?
    This is on Apple not Zoom. It happens in other software not just Zoom. Hopefully Apple fixes it in an update soon.
    So after more than one year of this bug, absolutely nothing change. So annoying. I have to do a presentation and share the screen of my IPad with a stable option, no wireless possible, and I can't. We send Artemis to the moon but it is impossible to connect properly an iPad and Zoom 🤣🤣🤣
    Hi.  Untick Airplay receiver.  Connect Ipad to mac with cable.  Select share screen Ipad via Airplay.  On Ipad select Zoom screen mirror not mac.  It takes 15 seconds to connect.  should work with or without cable
    Wow! amazing it works 🎉🎉🎉
    Thank you very much, you just saved me from a difficult situation, I have a professional presentation on Thursday and I didn't know what to do 🥳 , Apple couldn't give me answers, so thank you !!!!
    Thank you for your responsiveness, it's fabulous!
    Just want to add here that in December 2022, there are still users reporting this problem.
    It's not a Zoom issue, I actually came here to this forum because I was searching for answers regarding OBS. I've also tried using Wirecast and MimoLive, as well as OBS, and they all have exactly the same problem.
    I think it's fairly safe to say that the problem lies with apple's software, but they're not acknowledging the problem, and probably won't do anything about it.
    I suppose they're just assuming that the number of people who are even aware of this poorly documented software function is so low, they might as well not bother thinking about it.
    They fixed it in iOS 15. Hopefully they fix it again.  I wish they would quit breaking it!
    Apple released today iPadOS 16.2 and seems to be resolved. I recorded a test mini-screencast with screenflow of about 2 min, and no buzz here. Finally!
    Thanks! Awesome to hear! I’m downloading now.
    PLEASE let us know that this fix is confirmed!
    FIx confirmed here !
    iPadOs 16.2 on IPad Pro 11" model A2377 with MacBook Air M1 2020
    Everything is ok for the sharing with cable, no buzz at all.
