Jun 13, 2022 9:39 AM UTC
Setting Zoom Meeting to specifically 25 and 50 minutes
Hey so we wanted to implement a new system in our company. We wanted to install 25 minute meetings instead of 30 and 50 minutes instead of 60 minutes and we are wondering if there is anything which zoom does to allow for us to set it up as a manual process or can zoom install that for our specific company email?
Many thanks
    Jun 13, 2022 12:49 PM UTC
    Hi!  This would depend entirely on how you're scheduling the meetings as to the 'how', but when scheduling, you should be able to set any time you want.
    Jun 14, 2022 4:34 PM UTC
    Hey, @DD-GS ... here's my take on your question.
    If Zoom shut down meetings at the end of a meeting, then you'd probably see a finer granularity on the lengths.  But it's just a placeholder for a meeting length to Zoom.  You can end a 30 minute meeting in 1 minute, or in 29 hours (there's a 30 hour limit on paid accounts).  So just my opinion as a volunteer here in the Zoom Community: it's probably not something important to the vast majority of users.  But if it was important to enough people, Zoom might consider it.
    Us volunteers in the Zoom Community don’t have a way to handle feature requests. Please use this Zoom web page to make a feature request directly to Zoom staff:
    https://www.zoom.us/feed
    Jan 4, 2023 11:09 AM UTC
    I have a similar question. I want to set up 50-minute meetings but Zoom only offers 45 minutes or 60 minutes. So when I send a calendar invite to my group, they will see 45 minutes or 60 minutes. I will have to specify manually each time in my invitation to the group that the meeting is 50 minutes, even though Zoom says 45 minutes or 60 minutes?  I would like to set 50 minutes so everyone is clear without me having to enter 50 minutes manually in the invite. Thanks for your help on this.
    Jan 4, 2023 1:57 PM UTC
    I have the same issue. I am a psychologist and my appointments are 50 minutes, Before the upgrade, I could do this manually. Now I can't do that. Please advise.
    Jul 24, 2023 7:29 PM UTC
    I have sent a message directly to zoom support about this issue. Would be great if you could do the same. My appointments are also 50 minutes and now I cannot make this adjustment.
    Jan 4, 2023 2:03 PM UTC
    I am a psychologist and my appointments are 50 minutes (e.g. from 1:00 PM - 1:50PM.  Before the upgrade, I could do this manually. Now I can't do that. Please advise.
    Jan 4, 2023 8:38 PM UTC
    Hi, @drJR and @neilpw.
    Where were you setting the 50-minute duration:  on the Zoom Web Portal, on the Zoom desktop client, or a Google or Outlook appointment/meeting entry?
    The invitation links I get from the Zoom client app don't have a duration:
    I can't type into the minutes duration field on the Zoom Web Portal when creating a meeting, but I can type in the ending time field on the Zoom Desktop Client, which shows this entry on my Desktop Client:
    ... and this on the Web Portal:
    Using the Desktop Client might be a workaround for you.
    If the prohibition of typing a value into the Duration field on the Web Portal is "new" (I can't recall whether I ever tried it before, so I'm relying on your memory to say "I'm sure it is a recent change"), I'll ask some of my sources at Zoom whether this was an intentional change, or not.
    Also, I know Zoom tech staff does review Feature Requests, so please use this Zoom web page to enter a request for the functionality to be restored:
