Jan 22, 2025 8:10 PM UTC
Setting Up Smart Recording
I'm trying to set up Smart Recording with AI Companion but when I turn on the setting, I only have one option out of four that displays under 'create with each recording', what am i missing?
- we already use cloud recording
- our 'create audio' transcript is also checked on
Is this just a permissions thing?
Vinnie
Mar 15, 2025 1:53 AM UTC
Is this what you are talking about? You should be able to see that in your Zoom Portal:  "PERSONAL > Settings > AI Companion > Recording"
You should be able to see below screen if the Admin doesn't have it disabled and you have the minimum license required: Pro, Business or Enterprise.
I hope this helps. IF so, mark   (Accept as Solution)
Vinnie
