May 13, 2025 10:56 AM UTC
Setting audio output limit on zoom room?
Hello all,
 Is there any way for me to set a limit on how loud the volume can get on a zoom room controller? Currently we need to set the volume to about 25% as we get above that it gets way too loud
May 25, 2025 5:44 AM UTC
As an audio and broadcast engineer I can tell you that computer audio can be very complicated. That functionality is limited to the specific hardware. Some hardware like Q-SYS core 110f can be programmed. Some hardware may need to have the amplifier  volume limited so when the controller is at 100% the level is ok.
