Separate Interpretation Audio Stream | Community
  • July 19, 2023
  • 29 views
I would like to know if there is a way to get all the translation audio feed from one instance of zoom going to a separate audio canal. To be able to send separatly the languages feeds to a existing CMSI via Dante DVS or a soundcard. Without the need to open one session of zoom for each languages.
Thanks for your help
Best regards
RobertS
Hi @neoguiri
I know this is a very late answer, but I ws catching up with what has been going on over summer and only came across your question now. I use ZOOMISO to get an isloated feed from the Interpreters if I need to have everything comming off one machine. If you need anymore assistance, you can contact me at streamingwithinterpretation.com  - I will get a message immediately as I do not come onto this community site everyday.
Hi ! Could you explain how you get the translation in a separate channel in ZoomIso ??
